eds Posted December 24, 2010 Share Posted December 24, 2010 Hsppy Christmas folks! Driving home for Christmas and I looked in the wing mirror to see that I am puffing out extreme white smoke. When at low revs it is worst and as the revs increase it clears temporarily. Opened bonnet and there is a hiss which sounds like it is the cooling system but not sure where and maybe it is wet around engine bay. Opened expansion tank and it was empty. Lost heater too at same time as smoke started. The engine did not get over normal heat. Any ideas on what is the problem and whether I am safe to drive the hour dive home on boxing day. Thanks as usual for helping.......... Ed Quote Link to comment Share on other sites More sharing options...
Tom1809 Posted December 24, 2010 Share Posted December 24, 2010 You need to get some water back in here and take it slow, checking the temp gauge and taking stops to check fluid levels as it sounds very much like a head gasket failure, had it happen on my pajero, have you checked your oil to see if its milky? sorry not what you need at this time of the year, i would also be worried about warping the head if it hasn't already Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 24, 2010 Share Posted December 24, 2010 If there's no water in it the temp gauge won't be reading correctly, don't rely on it. Quote Link to comment Share on other sites More sharing options...
eds Posted December 24, 2010 Author Share Posted December 24, 2010 More I ask it sounds like the head gasket. I guess I will need it RAC relying home rather than drive anywhere. Thanks for the help so far, any more info much appreciated........ Ed Quote Link to comment Share on other sites More sharing options...
markyb Posted December 24, 2010 Share Posted December 24, 2010 300TDI? if so, head warp , book it in for a skim . not a bad to do either Quote Link to comment Share on other sites More sharing options...
rocky Posted December 24, 2010 Share Posted December 24, 2010 Hi, when I replaced the head gasket on my 300 I had the head skimmed and used Landrover gaskets and never had anymore problems. I certainly wouldn't run it as it is. Rocky Quote Link to comment Share on other sites More sharing options...
