steamman Posted December 24, 2010 Share Posted December 24, 2010 I have a 1991 Disco 200TDI and I require some info regarding the inner wing and front body mounts, I cannot find a maker of the mounts only the inner wing units. I wish to find out if the body mounts from Range Rover Classic are similar to the Disco 1, and are adaptable.as these parts are readily available. thank you Steamman. Quote Link to comment Share on other sites More sharing options...
Mark Posted December 24, 2010 Share Posted December 24, 2010 Which set of mounts are you referring to? the very front set in with the light box, or the next set back which attach into the footwell? Cheers Mark Quote Link to comment Share on other sites More sharing options...
fozsug Posted December 24, 2010 Share Posted December 24, 2010 This .jpg] or this .jpg] or this .jpg] All same a RRC available from YRM Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted December 25, 2010 Share Posted December 25, 2010 RRC and Disco1 have the same inner wing more or less. On a Disco you can see where the RRC wing would have stopped. The bulkhead is very similar too, the sills are identical and the rear wheelarch. It's basically the roof and rear quraters/boot that is different. Quote Link to comment Share on other sites More sharing options...
DrRob Posted December 25, 2010 Share Posted December 25, 2010 YRM all the way as the others have said....seen their stuff in the flesh. Very good stuff. Quote Link to comment Share on other sites More sharing options...
monkeyb0y Posted December 25, 2010 Share Posted December 25, 2010 The headlights ones on mime were rotten but if these are gone..so will the areas close like wheel arches...just make em yourself...cut one out...clone it in your shed twice...job done. Rich Quote Link to comment Share on other sites More sharing options...
