200tdi Discovery rear axle
LDRover
 Share
I changed the brake pads on my 200tdi Discovery rear axle the other day and found I need to repalce Disks, wheel bearing on one side(would do both) and rebuild the caliplers also. I am looking at about £150 for the parts, I am not sure if it is worth it with the list of jobs growing on the motor. Can I fit a 300tdi axle and just change the drive flange a outter seal.
Thanks.
I would see no reason why you could not fit a 300tdi axle and change the drive flange to match the better 200tdi system without the doughnut. My late 200tdi has 24 spline axles originally from the factory and it is common to upgrade to 300tdi axles from the older 10 spline.
Cheers
Ryck
 Share
