muddy4x4xfar Posted December 30, 2010 Share Posted December 30, 2010 hi does anyone know which of the front bulkhead wiring plugs are for the sender unit pump? i think its the plug with 5 wires going into it. i need to know as i have to make a loom from front to back. thanks in advance chris Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted December 31, 2010 Share Posted December 31, 2010 If you mean which of the multi-plugs at the bulkhead end has the power wires in for the fuel pump unit, then I think it's the black one, should have a large (ish) purple/white wire and maybe a solid purple one too. See first picture in this post : http://forums.lr4x4.com/index.php?showtopic=59892&view=findpost&p=526447 The sender unit wire (for fuel level signal) is in the grey one I think. Should be reen/black. Bear in mind the loom in that post is a ROW-spec loom, so only has the solid purple wire for the rear 12V aux point, no power for the fuel pump as ROW-spec vehicles only had a sender in the tank and no fuel pump as per Td5s. The plug is the same though. A copy of RAVE is invaluable for things like this Quote Link to comment Share on other sites More sharing options...
muddy4x4xfar Posted December 31, 2010 Author Share Posted December 31, 2010 cheers pal how do i get a hold of a copy of rave???? cheers chris Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted December 31, 2010 Share Posted December 31, 2010 http://landroveroneten.com/index.php/general/land-rover-manuals/ About 1/2 way down. Quote Link to comment Share on other sites More sharing options...
stuck Posted December 31, 2010 Share Posted December 31, 2010 Superb link. Thanks for that Quote Link to comment Share on other sites More sharing options...
