biggles Posted December 31, 2010 Share Posted December 31, 2010 Has anyone fitted the JE engineering uprated manifold studs on a TD5 defender? or does anyone know if it is worth doing? thanks Quote Link to comment Share on other sites More sharing options...
landy andy. Posted December 31, 2010 Share Posted December 31, 2010 No, but I have a complete set that I have not used. Has your exhaust manifold warped? or are you just trying to prevent this? They are standard strength studs but are much longer with a metal spacer, to go between the manifold and the nut. Strange only found the evelope containing these yesterday. Andy Quote Link to comment Share on other sites More sharing options...
Philip Tonkin Posted December 31, 2010 Share Posted December 31, 2010 I have IRB uprated studs (which are not studs at all) these also use a spacer like the JE ones. Certainly not had any manifold problems since fitting. Quote Link to comment Share on other sites More sharing options...
biggles Posted December 31, 2010 Author Share Posted December 31, 2010 No, but I have a complete set that I have not used. Has your exhaust manifold warped? or are you just trying to prevent this? They are standard strength studs but are much longer with a metal spacer, to go between the manifold and the nut. Strange only found the evelope containing these yesterday. Andy Thanks for reply Andy, no not warped, ive done quite a few mods to the engine and thought while im at it i may as well change the studs, just posted to see if any one had fitted them. If you was thinking of parting with them let me know, as i would be interested,do they have the spacers etc? Steve Quote Link to comment Share on other sites More sharing options...
landy andy. Posted December 31, 2010 Share Posted December 31, 2010 What are they then if not studs???????????????? Andy Quote Link to comment Share on other sites More sharing options...
Philip Tonkin Posted December 31, 2010 Share Posted December 31, 2010 They are bolts Quote Link to comment Share on other sites More sharing options...
biggles Posted December 31, 2010 Author Share Posted December 31, 2010 They are bolts What sort of price is Ian asking for them? Quote Link to comment Share on other sites More sharing options...
landy andy. Posted January 1, 2011 Share Posted January 1, 2011 Thanks Philip. Andy Quote Link to comment Share on other sites More sharing options...
Grant. Posted January 1, 2011 Share Posted January 1, 2011 Ive got the IRB bolts with the spacers, and have slightly warped a manifold whilst i had them(didnt know as it didnt whistle or screech), and nothing broke, worth there weight in gold for the hassle it saved! Quote Link to comment Share on other sites More sharing options...
