fan keeps comeing on
steerngo
my 1999 diesel freelander fan has started to come on even when cold and the engine has a odd power drop now and again, Ive checked oil and water levels, and renewed the fuel filter. now wondering if its a sensor or ecu type problem! any ideas?
ken
hi does your freelander have air con ?
if it does it will do as you report when the a/c compressor cuts in engine rpm will drop and recover and cooling fans will cut in & out. also if a/c is switched off and heater controls set to screen a/c is also automatical turned on.
hope this helps
hope this helps
Hi theres no air con, The problem seams intermittent, sometimes comeing on from cold.
ken
