V8 Freak Posted December 31, 2010 Share Posted December 31, 2010 Hello peeps, Wondering if the experienced people on here can help me understand what I should consider to help me improve my turning circle... I have a 110 currently with BFG MT's that are approximate. 32 inch diameter. I'm consideing a tyre change that may involve going up to 35 inches... What sort of offset should I be looking for to help me recover some turning circle and not totally screw my wheel bearings too regularly? Any wheel recommendations considered. Thanks in advance... Neil Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 31, 2010 Share Posted December 31, 2010 Buy a 90 Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted December 31, 2010 Share Posted December 31, 2010 Most off the shelf modulars are +8mm offset, which means the centre of the rim sits 8mm in from the centre of the hub flange, if that makes sense, most standard LR wheels are +33mm....... i have modulars with zero offset, but i only run 32's, so the 35's will most likely be wider.... so regular modulars i suspect would be your best compromise..... Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted December 31, 2010 Author Share Posted December 31, 2010 Buy a 90 Although I have considered this Mo, the investment in the 110 will never be recovered and I think that wheels & tyres could be a tad cheaper ! Neil Quote Link to comment Share on other sites More sharing options...
LowRanger Posted January 12, 2011 Share Posted January 12, 2011 Hello peeps, Wondering if the experienced people on here can help me understand what I should consider to help me improve my turning circle... I have a 110 currently with BFG MT's that are approximate. 32 inch diameter. I'm consideing a tyre change that may involve going up to 35 inches... What sort of offset should I be looking for to help me recover some turning circle and not totally screw my wheel bearings too regularly? Any wheel recommendations considered. Thanks in advance... Neil I run -22mm offset rims with 35"Trepadores on my 110 without any clearance problems.But you will need extended wheel arch flares.But the good thing is it widens your track for added stability. Wayne Quote Link to comment Share on other sites More sharing options...
