muddy4x4xfar Posted January 1, 2011 Share Posted January 1, 2011 (edited) Hi all . I've rebuilt my td5 engine, been setting up the rocker shaft for the injector set up. and when turning the crank by hand it felt very very tight. is this right ? will the starter motor be able to take it ? am i just panicing too much.??? any help would be much apprieciated . cheers everyone chris Edited January 1, 2011 by western edited to make it easier to read Quote Link to comment Share on other sites More sharing options...
western Posted January 1, 2011 Share Posted January 1, 2011 if your ritating the engine with the injectors & glowplugs fitted, it will be hard to turn over, the starter is designed to do this at speed & it has the gearing too, whereas you don't. Quote Link to comment Share on other sites More sharing options...
muddy4x4xfar Posted January 1, 2011 Author Share Posted January 1, 2011 ok cheers for that i feel much better i just wanter to make sure ... first time building an engine. happy new year. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted January 1, 2011 Share Posted January 1, 2011 Assuming the valve train is complete, and the cylinders are sealed (injectors and glow plugs fitted etc), you should be able to feel ( and hear) each cylinder build compression, and loose it, as the valves open and close. This means turning the engine over by hand will feel 'lumpy'. Quote Link to comment Share on other sites More sharing options...
