Bluemoon Posted January 1, 2011 Share Posted January 1, 2011 Just wondering if it was feasible or if anyone had already done it. Using Discovery 2 axles on a Defender 300tdi, but changing the hubs for the existing 300 series. I have been told you cant just swap the hubs for 300series hubs so I was thinking changing the stub axles as well, welding up any bolt holes as required and redrilling new , but don't know about the drive shafts and whether the brake calipers would be reused, and the finer details , anybody with some firm information would be gratefully appreciated . cheers Brian Quote Link to comment Share on other sites More sharing options...
bishbosh Posted January 2, 2011 Share Posted January 2, 2011 Sorry, can't help with your query, but I would ask why? Surely it is cheaper and easier to buy a set of disco 2 steel rims to fit your tires on? Then you can use the entire D2 axle? Or do you haver a cunning plan that you're not telling us about...? Quote Link to comment Share on other sites More sharing options...
Bluemoon Posted January 2, 2011 Author Share Posted January 2, 2011 just so I don't have carry two lots of spares, I want to keep all the wheels the same , to match the trailers and other motors . Brian Quote Link to comment Share on other sites More sharing options...
M&S Posted January 2, 2011 Share Posted January 2, 2011 Sounds like a lot of work. Why not stick with 300tdi axles?<br> Quote Link to comment Share on other sites More sharing options...
simonr Posted January 2, 2011 Share Posted January 2, 2011 Although I've not seen them recently, I've seen adaptor / spacer rings to put D1 wheels on D2's as well as D2 wheels on D1's. These would work equally well for a Defender. Rakeway might be a good company to ask? Si Quote Link to comment Share on other sites More sharing options...
Bluemoon Posted January 2, 2011 Author Share Posted January 2, 2011 are the disco2 diffs just bolt on? maybe an easier fix Brian Quote Link to comment Share on other sites More sharing options...
