landrover620 Posted January 5, 2011 Share Posted January 5, 2011 Hello, can anyone tell me if the early type hub seal RTC3511 will fit a later type hub fitted with a FTC4785 seal if so which is best to use. Thanks. Quote Link to comment Share on other sites More sharing options...
western Posted January 5, 2011 Share Posted January 5, 2011 RTC3511 is the better seal AFAIK, it should fit OK as the bearings are a common diameter as is the hub. Quote Link to comment Share on other sites More sharing options...
