bathroom man Posted January 6, 2011 Share Posted January 6, 2011 Hi there, could anyone tell me why i have up and down movement on my 99 td5 steering wheel, it has height adjustment and when locked there is movement, is there a bush that needs to be replaced or would anything have come loose. regards steve Quote Link to comment Share on other sites More sharing options...
fozsug Posted January 6, 2011 Share Posted January 6, 2011 Check the nut that holds the steering wheel on. If not it is probably wear in the colum assembly with the height adjustment. There doent apear to be any bushes listed to replace, only the whole assembly ! QMB000120PMA Quote Link to comment Share on other sites More sharing options...
bathroom man Posted January 6, 2011 Author Share Posted January 6, 2011 Check the nut that holds the steering wheel on. If not it is probably wear in the colum assembly with the height adjustment. There doent apear to be any bushes listed to replace, only the whole assembly ! QMB000120PMA thanks very much for the picture and advice,will check the steering wheel nut at the weekend. regards steve Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 6, 2011 Share Posted January 6, 2011 Usual method is get someone to jiggle it while you crawl round with a torch trying to see where the slack is and what needs tightening/fixing. Quote Link to comment Share on other sites More sharing options...
