FridgeFreezer Posted January 6, 2011 Share Posted January 6, 2011 Especially useful if you've got a dead microwave oven kicking about: http://hackaday.com/2009/06/23/how-to-build-your-own-spot-welder/#more-11565 Quote Link to comment Share on other sites More sharing options...
mickeyw Posted January 6, 2011 Share Posted January 6, 2011 Hmmm, like it's simplicity. One day when I have nought else to do/ need a spot welder.... Quote Link to comment Share on other sites More sharing options...
elbekko Posted January 6, 2011 Share Posted January 6, 2011 Well, I do have a microwave emitter laying about from an old microwave I took apart... I was thinking more along the lines of ray gun though, although I guess this could be handy too. Quote Link to comment Share on other sites More sharing options...
simonr Posted January 6, 2011 Share Posted January 6, 2011 I was thinking more along the lines of ray gun though, although I guess this could be handy too. Car alarm that gives you a nice 'warming' sensation - immediately prior to the painful head exploding death! Si Quote Link to comment Share on other sites More sharing options...
longlandy Posted January 6, 2011 Share Posted January 6, 2011 Quite a brutal design with the contacts permantly live, as with spot welding you should have a pre clamp time before power to ensure a clean good weld. BTW to spot weld aluminium stainless contacts make it successful Quote Link to comment Share on other sites More sharing options...
mickeyw Posted January 6, 2011 Share Posted January 6, 2011 Quite a brutal design with the contacts permantly live, as with spot welding you should have a pre clamp time before power to ensure a clean good weld. BTW to spot weld aluminium stainless contacts make it successful Is the contact material the only difference needed to weld ally? Quote Link to comment Share on other sites More sharing options...
longlandy Posted January 6, 2011 Share Posted January 6, 2011 Yes, though my statement is based on using a quality, but average sized welder.Experimentation is required on spot times. Zintec sheet can produce very unreliable welds. Quote Link to comment Share on other sites More sharing options...
Deej Posted January 6, 2011 Share Posted January 6, 2011 Is the contact material the only difference needed to weld ally? Makes sense as with spot welding you aren't adding additional material as with MIG/TIG etc, you are simply heating the two metal sheets in a localised area until they fuse together. Quote Link to comment Share on other sites More sharing options...
