Whiskeydog Posted January 6, 2011 Share Posted January 6, 2011 Hi guys, i'm new to the forum and am hoping you can help me figure out why its a real struggle to engage 1st & 2nd gear when starting on a journey first thing in the morning. After about 10mins driving through town, changing gears/starting stopping etc, things start to get easier and smoother. Any ideas? Thanks Quote Link to comment Share on other sites More sharing options...
landy andy. Posted January 6, 2011 Share Posted January 6, 2011 This is normal, but can be improved by using fully sythetic oils such as "Difflock" oils. It will be much better when the weather warms up a bit. Andy Quote Link to comment Share on other sites More sharing options...
western Posted January 6, 2011 Share Posted January 6, 2011 change the fluid & fill with either the LR MTF84 or Difflocks Evo1 as suggested above. MTF94 in my R380 never had any gearchange problems with it. Quote Link to comment Share on other sites More sharing options...
Whiskeydog Posted January 9, 2011 Author Share Posted January 9, 2011 Brilliant, thats a weight off my mind, didnt know if if it was something serious or not. Thanks a lot guys Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted January 10, 2011 Share Posted January 10, 2011 As a long-time user of MTF94 until my 20l drum ran out I switched to Redline Oil MTL and found the gearchange to be even better. The advantage of these fully-synthetic oils is that they are completely heat-proof and don't wear out so never need to be changed. The improvement in the gear change is because these oils are engineered to have a HIGHER coefficient of friction and this helps the synchros. If the oil is too 'slippery' the synchro cones can't get a grip. Makes some sense, eh? Oh, and the disadvantage is that they cost a lot. But if you never need to change the oil.... Quote Link to comment Share on other sites More sharing options...
JJB Serenity Posted January 10, 2011 Share Posted January 10, 2011 Would that work in my gearbox Jim? (the original gearbox in my 200Tdi) Quote Link to comment Share on other sites More sharing options...
tacr2man Posted January 10, 2011 Share Posted January 10, 2011 The redline will work in your box , any that specifies a MTL or ATF . I have used for years in my LT85 and swear by REdline oils ( no comercial interest) I was converted in Australia , which really sorts vehicle Weaknesses. Quote Link to comment Share on other sites More sharing options...
