jonny555 Posted January 6, 2011 Share Posted January 6, 2011 Hi All, Ive got a problem !! I've just changed the head gasket on my Range Rover 300TDI. it started straight away which i was please about. I notice that oil fumes where puffing out the oil filler cap I went tuen it off staight away but by the time I got there it had forced all the oil out the sump from all over the place !!! do you think the head gasket has failed straight away and pressurised the oil system ? or could there be another explaination ? I had the head pressure tested and skimmed before re-fitting it. any advice would be most helpfull ! also it's done 227000 ! so is it worth just replacing the whole engine ? thanks Jon Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 7, 2011 Share Posted January 7, 2011 Why did you replace the head gasket in the first place i.e. was it doing this before or if not what was it doing? Quote Link to comment Share on other sites More sharing options...
Typsey Posted January 10, 2011 Share Posted January 10, 2011 Did you fit the head gasket the right way round? Mate of mine didn't and ended up with similar problem. Quote Link to comment Share on other sites More sharing options...
