bushwhacker Posted January 6, 2011 Share Posted January 6, 2011 O boy what next. I have done the p gasket and cant get heat to the inside blower. Filled rad to plug hole. Filled up to thermo housing plug. Raised the expansion tank. Squeezed the hoses and even cursed a few times and no joy. It is not boiling up or pressurising the expansion tank and the gauge sits just under halfway so a dodgy water pump maybe. Any thoughts of the helpful kind please. Quote Link to comment Share on other sites More sharing options...
jad Posted January 6, 2011 Share Posted January 6, 2011 You can try taking a heater pipe off the back of the head, hold it above the heater and pour water in the pipe (Or use a hose pipe) and wait until water comes out of the block, then put the heater pipe back on trying to let as little air in as possible while doing so, and make sure the jubilee clip is already on. Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted January 7, 2011 Author Share Posted January 7, 2011 I'll give that a go jad. New thermostat hasn't worked. If raising the hose does'nt work I'll try a water pump. Then if all that fails it will be matches and a litre of petrol or would a gallon be cheaper. Can you still get a gallon now adays. Thanks Quote Link to comment Share on other sites More sharing options...
fozsug Posted January 7, 2011 Share Posted January 7, 2011 Flush the heater matrix out and flush the whole circuit out with one table spoon of dish washer powerder, then flush with clean water both ways. If not then blow out the breather pipes from the thermostat housing to the black ball and from the radiator to the black ball. Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted January 7, 2011 Author Share Posted January 7, 2011 Thanks. But the black ball? Quote Link to comment Share on other sites More sharing options...
fozsug Posted January 7, 2011 Share Posted January 7, 2011 Sorry meant this Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted January 7, 2011 Author Share Posted January 7, 2011 Thanks for help guys but still no joy, awell. I can get water to circulate with the garden hose plumbed in (but can't drive far) . System now washed out unfortunately the new anti freeze went with it. I will have to try a new water pump next week. Quote Link to comment Share on other sites More sharing options...
fozsug Posted January 8, 2011 Share Posted January 8, 2011 Thanks for help guys but still no joy, awell. I can get water to circulate with the garden hose plumbed in (but can't drive far) . System now washed out unfortunately the new anti freeze went with it. I will have to try a new water pump next week. Buy a genuine pump, its worth the extra pennies Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted January 8, 2011 Author Share Posted January 8, 2011 If that doesn't cure it, I will have to find a new home for it. Urgent need for cash to repair my 200 Dis offroader/onroader with a blown head gasket, I'm thinking £2oo ish. Fingers crossed. My 110 and not forgetting the RR also need finished. Oboy Oboy. The new owner if I get one WILL be told about the problem. and they can take it or leave. Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted January 16, 2011 Author Share Posted January 16, 2011 Just for anyone interested. 300 Disco now providing heat, why is it not snowing now. New water pump QH type from my local LR place BLRC sorted it. The impeller on the old one was loose on it's shaft. Quote Link to comment Share on other sites More sharing options...
