SPendrey Posted January 9, 2011 Share Posted January 9, 2011 Nothing more than a rant and rave... but I bet the person who designed the rear light cluster on a 300TDI hasn't ever changed the rear/stop light Why is it so difficult to do? End of rant. Quote Link to comment Share on other sites More sharing options...
dooroy Posted January 9, 2011 Share Posted January 9, 2011 I often wonder about the word 'design' as it applies to cars. As for the Discovery - having had a few tussles changing bulbs in 7 seaters - I now remove the rear lens . I find it easier to manage the screws holding on the lens than trying to remove and replace a bulb. Quote Link to comment Share on other sites More sharing options...
axlechorus Posted January 9, 2011 Share Posted January 9, 2011 Its is pain in the ****. However thinking about it at least LR didn't do what fiat did for my punto front headlight and put a fuse box right behind where you popped the back of the headlight off Quote Link to comment Share on other sites More sharing options...
nicedayforit Posted January 9, 2011 Share Posted January 9, 2011 If you do need to replace a bulb in the rear cluster, replace them all while you are at it. Quote Link to comment Share on other sites More sharing options...
Dannytd5 Posted January 9, 2011 Share Posted January 9, 2011 The 99-2002 discovery rear brake blub is a pain too you unscrew 4 screws the lamp comes off then you see a further 10 screws holding the bulb holder thingy in which ever monkey designed it never planned to own one and change a bulb Quote Link to comment Share on other sites More sharing options...
MartinK Posted January 10, 2011 Share Posted January 10, 2011 I replaced all mine with LED versions, they last a lot longer. A very worthwhile upgrade. Usually around £4 for 2 off ebay... If in doubt, try this website http://www.autobulbsdirect.co.uk/ Quote Link to comment Share on other sites More sharing options...
leon_81 Posted January 10, 2011 Share Posted January 10, 2011 It is a massive pain in the ass, but my old car was worse - that was a grill and headlight out job to change a bulb! Quote Link to comment Share on other sites More sharing options...
disco_al Posted January 10, 2011 Share Posted January 10, 2011 most modern cars require the front end to be dismantled to change a bulb. recently had a customer on the phone who had been quoted £60+vat to have a headight bulb changed on a galaxy (at the main dealer) IIRC xsara picasso's require the bumper to be removed to get at the bulbs. Quote Link to comment Share on other sites More sharing options...
LR NUT Posted January 10, 2011 Share Posted January 10, 2011 It is a massive pain in the ass, but my old car was worse - that was a grill and headlight out job to change a bulb! Both of my D2's are like that! Quote Link to comment Share on other sites More sharing options...
SPendrey Posted January 10, 2011 Author Share Posted January 10, 2011 Its is pain in the ****. However thinking about it at least LR didn't do what fiat did for my punto front headlight and put a fuse box right behind where you popped the back of the headlight off most modern cars require the front end to be dismantled to change a bulb. recently had a customer on the phone who had been quoted £60+vat to have a headight bulb changed on a galaxy (at the main dealer) IIRC xsara picasso's require the bumper to be removed to get at the bulbs. Ah, my previous car was a Galaxy (2000 MY), but I don't recall it being a pain (other than the auto gearbox failing!). Funnily enough I also owned a Punto many years ago! Quote Link to comment Share on other sites More sharing options...
auf_wiedersehen_pet Posted January 11, 2011 Share Posted January 11, 2011 Going back to the original post - the 300tdi cluster was originally from a Montego estate. No wonder it doesn't fit. Quote Link to comment Share on other sites More sharing options...
disco_al Posted January 11, 2011 Share Posted January 11, 2011 Going back to the original post - the 300tdi cluster was originally from a Montego estate maestro van was where the light clusters were robbed from, and the door handles from the marina Quote Link to comment Share on other sites More sharing options...
Pwyll Posted January 11, 2011 Share Posted January 11, 2011 maestro van was where the light clusters were robbed from, and the door handles from the marina Let's face it, most of the Disco fixtures and fittings came from whatever parts bin was closest and fullest when they were "designing" it. Otherwise known as Midlands engineering. Quote Link to comment Share on other sites More sharing options...
