klint Posted January 10, 2011 Share Posted January 10, 2011 Hi, i want an advice from you: my td5 defender (2004) have an horrible knocking sound at first 5-6 second from cold startup every morning.it's like a tumf tumf tumf, it comes out from bottom of the engine. I'm using a Castrol diesel magnatec 5w-40 oil and this have 2000km on it, oil filter is new, and the level is ok. What could be?? Quote Link to comment Share on other sites More sharing options...
ashtray Posted January 10, 2011 Share Posted January 10, 2011 whats the mileage? service history good? Quote Link to comment Share on other sites More sharing options...
voevod Posted January 11, 2011 Share Posted January 11, 2011 as far as I know the 5 refers to the oil's "cold" viscosity i.e.on startup...maybe you should get a thicker grade of oil Quote Link to comment Share on other sites More sharing options...
landy andy. Posted January 11, 2011 Share Posted January 11, 2011 Is this noise caused by the lack of the fifth glow plug, so one cylinder is not running correct until it has warmed up ????????? Andy Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted January 11, 2011 Share Posted January 11, 2011 Hi Klint, did you post this on the Landyonline forum as well? Not that it matters really, just nice to see others on both foræ BTW you shouldn't use that cr@p oil. LR stealers™ use it, I have no idea why, some sort of bribery no doubt. Castrol Magnatec is a CF oil if you look at the tin; you should be using at least a CH in the TD5. Ignore the S(park) ratings for petrol engines. The C stands for C(ompression) Ignition ie diesel. Quote Link to comment Share on other sites More sharing options...
klint Posted January 12, 2011 Author Share Posted January 12, 2011 Hi Klint, did you post this on the Landyonline forum as well? Not that it matters really, just nice to see others on both foræ BTW you shouldn't use that cr@p oil. LR stealers™ use it, I have no idea why, some sort of bribery no doubt. Castrol Magnatec is a CF oil if you look at the tin; you should be using at least a CH in the TD5. Ignore the S(park) ratings for petrol engines. The C stands for C(ompression) Ignition ie diesel. Here there is the recording of the strange sound,keep attention since 0:12..(raise speaker leve) help please!! advice?? ideas??? Quote Link to comment Share on other sites More sharing options...
