Part nos
Phil B
Hi just after a couple of numbers,
Water Temp sensor for a 300tdi (94) my needle goes loopy above a certain temp,
Decat with and without flexi joint,
Middle box removal think my spurious setup has a slip joint tho so could be a new setup in thee end
I know the last two aren't oe equipment but I can only really find them in stainless and im after mild steel
temp sender is err2081
exhaust wise, paddocks do a "performance exhaust" for about £50, which is the rear section and a straight middle pipe.
front pipe wise, you need an LR196J (Timax number) which has a cross reference of ESR2740, that's the flexi one. I've got a front pipe of a 110 on mine IIRC which was a LR197H (ESR2297), which doesn't have the flexi, and so is a bit cheaper.Assuming of course this is for a disco......
