Phil B Posted January 12, 2011 Share Posted January 12, 2011 Hi just after a couple of numbers, Water Temp sensor for a 300tdi (94) my needle goes loopy above a certain temp, Decat with and without flexi joint, Middle box removal think my spurious setup has a slip joint tho so could be a new setup in thee end I know the last two aren't oe equipment but I can only really find them in stainless and im after mild steel Quote Link to comment Share on other sites More sharing options...
disco_al Posted January 12, 2011 Share Posted January 12, 2011 temp sender is err2081 exhaust wise, paddocks do a "performance exhaust" for about £50, which is the rear section and a straight middle pipe. front pipe wise, you need an LR196J (Timax number) which has a cross reference of ESR2740, that's the flexi one. I've got a front pipe of a 110 on mine IIRC which was a LR197H (ESR2297), which doesn't have the flexi, and so is a bit cheaper.Assuming of course this is for a disco...... Quote Link to comment Share on other sites More sharing options...
Phil B Posted January 12, 2011 Author Share Posted January 12, 2011 Yah it is, I've tuned and intercooled my truck and It's bit gutless, I'm gonna repipe the actuator then go exhaust mods then timing, But it needs the free flow so I can tow my cattle trailer economically Quote Link to comment Share on other sites More sharing options...
Phil B Posted January 12, 2011 Author Share Posted January 12, 2011 Also I might go solid as I think the flexi is leaking whichll bugger flow up Quote Link to comment Share on other sites More sharing options...
western Posted January 12, 2011 Share Posted January 12, 2011 300Tdi water temp sensor is AMR1425 Green top or AMR3321Black top ERR2081 is for the EGR system not the temp gauge. Quote Link to comment Share on other sites More sharing options...
