door frames
hi
dont think you can buy just the frames could be wrong.i think most people cut out the rot and weld in some angle iron or box section of a similar size hope this helps.some grown up will be along shortly with the correct answer no doubt
thanks for the replies. i've got some repair sections from yrm, unfortunately the tin worm is all up the sides of the middle row doors, looks like fleabay for complete 2nd hand replacements
The side section should be the same as the lower edge (until you get to the radiused bit), just buy a few more repair sections.
