old & wrinkly Posted January 14, 2011 Share Posted January 14, 2011 about 3 months ago i lost the diff lock light . I tried a new bulb but nothing changed ! i then checked for power at the switch itself everything was OK. unscrewed the switch from the box connected the wires pressed the button on the bottom of the switch and hey presto the light comes on!!!! soon as i put it back there,s nothing ???? any ideas Quote Link to comment Share on other sites More sharing options...
disco_al Posted January 14, 2011 Share Posted January 14, 2011 sounds like the switch is just worn. will it screw in another turn or two? that might make a difference. Quote Link to comment Share on other sites More sharing options...
Frax Posted January 14, 2011 Share Posted January 14, 2011 Are you sure that the diff lock is working ? Frax Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 14, 2011 Share Posted January 14, 2011 The swithces can be fussy about adjustment, as suggested above try screwing it in/out until it behaves then do the locknut up, it's why it's there. Quote Link to comment Share on other sites More sharing options...
old & wrinkly Posted January 14, 2011 Author Share Posted January 14, 2011 Thanks guys. Its begining to make sense now.. I may have to find a thinner lock nut or copper washers so the switch will go in further as its right down on the nut at the moment so its not possible to adjust... the diff locks work perfect. Quote Link to comment Share on other sites More sharing options...
