RRMatador Posted January 18, 2011 Share Posted January 18, 2011 Hello everyone, although there are countless threads i've read on this matter, i couldnt find a relevant fix. My P38 has never given me any starting probs - fired 1st or 2nd crank always...until yesterday. It's now a pig to start and i seem to have a lot of air in the fuel line - even when the engine is running. Anything i should be checking apart from split pipes, which upon first glance seem ok? TIA Regards Matt Quote Link to comment Share on other sites More sharing options...
Escape Posted January 19, 2011 Share Posted January 19, 2011 The easy fix is to put a non-return valve between the filter and the feed from the tank. If the starting problems only occur when the car has been sitting overnight, this should be solve it (as it did with mine). If it happens every time, even after standing for only a short time, I'd look for leaks. Likely suspects are the fuel return lines on the injectors or the connections to the injection pump. Greetz, Filip Quote Link to comment Share on other sites More sharing options...
pete3000 Posted January 19, 2011 Share Posted January 19, 2011 http://forums.lr4x4.com/index.php?showtopic=62977 worked for me, bit biased as I wrote it. Quote Link to comment Share on other sites More sharing options...
RRMatador Posted January 22, 2011 Author Share Posted January 22, 2011 Thanks guys. A pretty definitive answer... Quote Link to comment Share on other sites More sharing options...
