MogLite Posted June 28, 2006 Share Posted June 28, 2006 How much oil does my PTO need ? I'm assuming its EP90, but I don't know. The PTO is a rear facing one as fitted to an LT230 when used with a hydraulic pump, not the chain driven drop PTO. There is a top fill, but I can't see any level marks etc Ta Quote Link to comment Share on other sites More sharing options...
will_warne Posted June 28, 2006 Share Posted June 28, 2006 How much oil does my PTO need ?I'm assuming its EP90, but I don't know. The PTO is a rear facing one as fitted to an LT230 when used with a hydraulic pump, not the chain driven drop PTO. There is a top fill, but I can't see any level marks etc Ta Have you got any pictures? I know with the underdrive the oil is only filled about a third of the way up the unit then it maintains its own level by draining into the transfer box and having extra oil splashed up. Maybe this uses a simerlar system? Quote Link to comment Share on other sites More sharing options...
MogLite Posted June 28, 2006 Author Share Posted June 28, 2006 Have you got any pictures? I know with the underdrive the oil is only filled about a third of the way up the unit then it maintains its own level by draining into the transfer box and having extra oil splashed up. Maybe this uses a simerlar system? I suspect its very similar Will. I have some piccies at home - I'll post em up tonight. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted June 28, 2006 Share Posted June 28, 2006 Doubleo Posto Nige Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted June 28, 2006 Share Posted June 28, 2006 Yep EP 90. It fills through the hole, but also levels with the TBox, so check Tbox level too, ie if you overfill PTO it leaks into TBox levels, raising them a tad... A heath robinson arrangement, and it will just be another weeping leak shortly........ Nige Quote Link to comment Share on other sites More sharing options...
