DiscoHere Posted January 22, 2011 Share Posted January 22, 2011 Hi Guys My rear door is a little off liine and not closing as easily as it used to. I think the reason is wear in the hinges. Does anyone know if it is possible to replace the pins in them or should I replace the hinges themselves? Hugh Quote Link to comment Share on other sites More sharing options...
bmhor Posted January 22, 2011 Share Posted January 22, 2011 It is possible to replace the pins but you will need a source of heat (oxy/accet worked for me) a punch of the right size, a large hammer and someone else to hold the punch in case you miss with the hammer....... Much easier and safer to replace hinge.. Bob Quote Link to comment Share on other sites More sharing options...
DiscoHere Posted January 26, 2011 Author Share Posted January 26, 2011 Thanks Hugh Quote Link to comment Share on other sites More sharing options...
mahon257 Posted January 26, 2011 Share Posted January 26, 2011 Hi Guys My rear door is a little off liine and not closing as easily as it used to. I think the reason is wear in the hinges. Does anyone know if it is possible to replace the pins in them or should I replace the hinges themselves? Hugh There is "some" adjustment possible - at both the hinge side - and the latch (locking side). The 2 x door hinges are bolted to free-floating steel plates. The idea... loosen all 6 bolts - enough to free up the hinges - but keep them attached to the car. You then need someone to hold up the boot door - whilst you re-tighten the hinges bolts. It will take alot of experimentation - but you should be able to improve things... If that doesn't work... you can also adjust the latch bolt (it is also mounted on a floating plate). Cheers Nick Quote Link to comment Share on other sites More sharing options...
