landy V8 Posted January 24, 2011 Share Posted January 24, 2011 hi all which would be a good ratio transfer box to go for in my 110.i'm running 35" tyres,200tdi. at the mo it's revving out at about 50/60.looking to lower the revs while gaining some top end and hopefully getting a bit more fuel economy to boot. thanks for any info Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 24, 2011 Share Posted January 24, 2011 What have you got in there now? Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted January 24, 2011 Share Posted January 24, 2011 It would have been built with 1.4:1 or thereabouts. If it's running out of steam at 50.60 then raising the gearing mgith mean it never reahes it's peak power for cruising at all. Plus the speedo will now be reading slow (or actually might now be accurate) because the tyres are bigger. Quote Link to comment Share on other sites More sharing options...
landy V8 Posted January 24, 2011 Author Share Posted January 24, 2011 haven't had a look as yet. there's plenty of power.but it's just revving it's nuts off.it would definately go quicker,i'd just end up doing gallons per mile instead of the other way round. speedo is spot on Quote Link to comment Share on other sites More sharing options...
90200tdi Posted January 25, 2011 Share Posted January 25, 2011 Hi, if its an early 110 it could have a 1.6 transfer box, later 110's and all 90's have 1.4 transfer boxes, and disco's have 1.2 ratio transfer boxes. If you have a 1.6 ratio you can change it for a 1.4 ratio and it should bring your revs down. Quote Link to comment Share on other sites More sharing options...
KKMobile Posted January 25, 2011 Share Posted January 25, 2011 Hi, if its an early 110 it could have a 1.6 transfer box, later 110's and all 90's have 1.4 transfer boxes, and disco's have 1.2 ratio transfer boxes. If you have a 1.6 ratio you can change it for a 1.4 ratio and it should bring your revs down. ^^^^ What he said ^^^^ Running 34's with 1.410 ratio box no problems!! Quote Link to comment Share on other sites More sharing options...
landy V8 Posted January 25, 2011 Author Share Posted January 25, 2011 i'll see about getting hold of a 1.4 and see how it goes. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted January 25, 2011 Share Posted January 25, 2011 Confirm what you have first. I'd have thought that with a 200Tdi and 35" tyres, putting a 1.2 box on might hinder your accelleration somewhat, but only one way to find out for sure! Quote Link to comment Share on other sites More sharing options...
landy V8 Posted January 25, 2011 Author Share Posted January 25, 2011 i'll have a look tomorrow and see what i've got.then i can pick which one to try. if it's a, 1.6 i'll try a 1.4 1.4 i'll try a 1.2 cheers for the advice Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 25, 2011 Share Posted January 25, 2011 Or you could try science and use the gear ratio calculator in the tech archive. Quote Link to comment Share on other sites More sharing options...
LiamC Posted January 26, 2011 Share Posted January 26, 2011 I had a 1.4 box in my 110 and I've just changed it for a disco 1.2 box and its sooooo much better! I have normal 235/85/16 tyres and the gearing now is just right for normal use, perhaps a little high when fully laden but overall much better. However I wouldn't want to go any higher so if I had bigger tyres I would think the 1.4 box would be the way forward. Indeed check what you've got, there's usually a sticker on the box but if not you can work out the ratio from the serial number. Quote Link to comment Share on other sites More sharing options...
