Les Brock Posted July 1, 2006 Share Posted July 1, 2006 Well not sure what to do about the rear winch ???? Rebuilding the truck.....so do I..while all the rear tubs in bits..... Use the Husky I already have in the Southdown removable tow hitch cradle ? Take the oppertunity that its in bits and fit a cradle for another 8274, (same winches front and rear) Use the Lt230 Hydraulic PTO with the 22cc per revolution, what ever output that is pump ? , I also have a spool block etc and stick a Milemarker in ? Also what's my Hydraulic PTO with a brand spanking new pump worth ? and how much should I ask for the H14W I took off with the PTO and shafts etc ? how much is the Husky worth ?, I bought it brand new in 04) If I go the 8274 route, I need to fund the second one ! do I have to much stuff ? Quote Link to comment Share on other sites More sharing options...
SteveG Posted July 1, 2006 Share Posted July 1, 2006 aren't people now putting three winches on!! So PTO Hydraulic on the back and Husky in the middle Have no idea what the Hydraulic one is worth but the husky would go for 600+ I would guess. They seem to go very easily on ebay when they come up for auction Steve Quote Link to comment Share on other sites More sharing options...
JST Posted July 1, 2006 Share Posted July 1, 2006 Husky in the rear. you can use an electic winch when the vehicle needs putting back onto 4 wheels after a roll etc, cant do that with a hydraulic one if you need to run the engine! Quote Link to comment Share on other sites More sharing options...
Ex Member Posted July 1, 2006 Share Posted July 1, 2006 Husky. Nice and safe for lowering down hills. Quote Link to comment Share on other sites More sharing options...
will_warne Posted July 1, 2006 Share Posted July 1, 2006 Husky. Nice and safe for lowering down hills. Les, for what you'll be doing you want to keep the Husky or maybe an 8274 at a push. Quote Link to comment Share on other sites More sharing options...
Les Brock Posted July 2, 2006 Author Share Posted July 2, 2006 How much difference in speed is changing the motor from a bogger to a decent spec ? Snail to Tortoice ? Is it true if you fit a 4.6 due to motor resistance of summat ??????, it is possible to overcome the worm and wheel, and go into free fall ? Quote Link to comment Share on other sites More sharing options...
will_warne Posted July 4, 2006 Share Posted July 4, 2006 How much difference in speed is changing the motor from a bogger to a decent spec ?Snail to Tortoice ? Is it true if you fit a 4.6 due to motor resistance of summat ??????, it is possible to overcome the worm and wheel, and go into free fall ? I've got a 4.6 in mine and its still really slow. I think you're probably OK with a 4.6 but it is an issue. Quote Link to comment Share on other sites More sharing options...
dollythelw Posted July 4, 2006 Share Posted July 4, 2006 I still like a 45m strop Quote Link to comment Share on other sites More sharing options...
Les Brock Posted July 4, 2006 Author Share Posted July 4, 2006 My Missus can throw a strop for weeks when she finds I've bought something else for the "thing" that takes all my time up I still like a 45m strop Quote Link to comment Share on other sites More sharing options...
dollythelw Posted July 4, 2006 Share Posted July 4, 2006 £30 ish fella from lifting and crane - not so tasty on conniferous bark but on deciduous its lovely I know what you mean on the wife front................. just hide the receipt and pretend you've always had it Quote Link to comment Share on other sites More sharing options...
MogLite Posted July 4, 2006 Share Posted July 4, 2006 Husky in the rear.you can use an electic winch when the vehicle needs putting back onto 4 wheels after a roll etc, cant do that with a hydraulic one if you need to run the engine! That is a pretty good point. With an electric rear winch, you should be able to drag yourself out of most things in an emergency even with a dead engine. I'm not clever enough to engineer hydraulic so it brakes correctly Husky is a perfect rear winch IMHO, an 8274 is pretty scary when you rely on the brake, it might work, but its still scary. If you need a fast rear winch, I suspect you could look at your rigging options as an alternative. Solenoids and motors will interchange between 8274 <-> Husky, so spares is a moot point. why are you ditching the H14 ? Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted July 4, 2006 Share Posted July 4, 2006 Les, Andy has just said what I was going to say - but I am more clever on the hydraulics! Quote Link to comment Share on other sites More sharing options...
Les Brock Posted July 6, 2006 Author Share Posted July 6, 2006 Andy getting shot of the H14, cause I'm fed up of, faffing about with engaging this that and the other, rather than just pressing the button, Alright for occasional use....but not for what I need it for Quote Link to comment Share on other sites More sharing options...
madmatt Posted July 8, 2006 Share Posted July 8, 2006 Braking a Hydraulic winch is no big deal all you need is a load hold valve or over centre valve plumbed into the system as close to the winch motor as possible. Quote Link to comment Share on other sites More sharing options...
