Les Brock Posted August 29, 2005 Share Posted August 29, 2005 Needed so I can get the truck back together....so I can get it to Allisport for tuning Cheers Quote Link to comment Share on other sites More sharing options...
Fatboy Posted August 29, 2005 Share Posted August 29, 2005 Les, Unless I am confused... , your truck should have two. If you've bent one (other post), the other one should still be okay... Can you not measure that? If I've missed the point then tell me the exact datum points of the component you want measured and I'll get my coat.... and tape measure and go forth! Quote Link to comment Share on other sites More sharing options...
Les Brock Posted August 29, 2005 Author Share Posted August 29, 2005 Donald, Thanks for the reply, the front one is fine, but a completly different length, the one that knackered is the long one behind the diff looking from the front best datum points would I think be centre of track rod to centre of track rod Thanks for all your effort and hopefully its a concrete drive and not to wet/muddy Quote Link to comment Share on other sites More sharing options...
Bush65 Posted August 29, 2005 Share Posted August 29, 2005 What I know as the drag link, connects the pitman arm to the steering arm (runs more or less parallel with the panhard rod) in front of the front axle!! And there is only one!! Quote Link to comment Share on other sites More sharing options...
landrover598 Posted August 29, 2005 Share Posted August 29, 2005 mines 1228mm Quote Link to comment Share on other sites More sharing options...
Les Brock Posted August 29, 2005 Author Share Posted August 29, 2005 Errrr.... well its the one that links both the wheels together below the front prop, as in when the one wheel moves it drags the other one effectivley, so I thought this was the drag link ! but then again I'm usually wrong Quote Link to comment Share on other sites More sharing options...
Mark90 Posted August 29, 2005 Share Posted August 29, 2005 It's yer track rod mate. As in it adjusts the tracking. Quote Link to comment Share on other sites More sharing options...
Fatboy Posted August 29, 2005 Share Posted August 29, 2005 Les, Drag link as Bush 65 says is From Steering box to hub, mine is 860mm and my coat is firmly on.... Thats from the end of the tube to the end of the tube. My Track rod is 1180mm from end of tube to end of tube but this includes the adjuster piece. The longest piece of the tube is 1045mm. For some obscure rerason, I was thinking of the suspension arms, back axle. Sorry for the confusion.... Quote Link to comment Share on other sites More sharing options...
Niall_CSK Posted August 30, 2005 Share Posted August 30, 2005 Thinking of Trailing Link (Rear Radius Arms) the one between the chassis and axle, stud on axle end and one bush eye on the axle end? Quote Link to comment Share on other sites More sharing options...
Fatboy Posted August 30, 2005 Share Posted August 30, 2005 Niall, Thems the kiddies!!! I can never remember what they are called and just put 2+2 when Les sayed he had really bad handling.... I was thking "I'll bet you have if you've bent one of those.." Quote Link to comment Share on other sites More sharing options...
