Guest diesel_jim Posted July 3, 2006 Share Posted July 3, 2006 I was in Bearmach in Swindon today, getting some bits, one of the parts i need is a new starter for my 300Tdi (defender) they can supply 3 kinds, genuine £202! valeo (which mine already has, lasted quite well) for about £130 ish, and a prestolite for £80. So.... are the el-cheapo prestolite cheap quality too? the genuine one is out of the equasion, as i'll go for valeo if nothing else, i just wondered if by saving £50 i'll be buying shed loads of hassle? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 3, 2006 Share Posted July 3, 2006 Prestolite are carp. I fitted a new one, it didn't work. Replaced it and that one busted the next day, replaced it again and the third one didn't last 6-months. Les. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 3, 2006 Share Posted July 3, 2006 Can you get your old one reconditioned locally? Might be the cheapest option and at least you know the base unit is a decent one. Quote Link to comment Share on other sites More sharing options...
GBMUD Posted July 3, 2006 Share Posted July 3, 2006 FWIW I got a Valeo one when mine expired. I was told that was OE. Chris Quote Link to comment Share on other sites More sharing options...
Mark90 Posted July 3, 2006 Share Posted July 3, 2006 I had a prestolite one, wouldn't bother again Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 3, 2006 Share Posted July 3, 2006 The genuine ones are Bosch IIRC, because we had some from Bearmach a while back and they even had the LR logo stamped into the casing (except without the expensive box), and you can't get closer to Genuine than that Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted July 3, 2006 Share Posted July 3, 2006 Hmmm.... definately a no-no to presto-carp then! I'll go with another valeo, it seems to have lasted quite well to the grief I gave it. I thought about getting mine overhauled (as it's only the solenoid thats causing some grief) but then thought "well, the rest of it is probably worn too, brushes, maybe bearings etc" so i'll just stick a new one in there. Thanks all! Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 3, 2006 Share Posted July 3, 2006 Jim - Dieselec 'Gas and Go' on the station industrial estate near the railway station rebuild starters and alternators. I think you can get brushes etc from them as well, but on some starters you need a high temperature solder iron to attach the braid cable. I buy solenoids etc from them. Les. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted July 3, 2006 Share Posted July 3, 2006 Jim - Dieselec 'Gas and Go' on the station industrial estate near the railway station rebuild starters and alternators. I think you can get brushes etc from them as well, but on some starters you need a high temperature solder iron to attach the braid cable. I buy solenoids etc from them.Les. Cheers for that Les, i'll pop down and see how much. Quote Link to comment Share on other sites More sharing options...
Jon White Posted July 3, 2006 Share Posted July 3, 2006 I fitted a brand new, genuine (expensive!) lucas one to my V8 not long ago - its not started the engine more than 2 dozen times and its gone clicky already! Sigh.......... Jon Quote Link to comment Share on other sites More sharing options...
Gromit Posted July 4, 2006 Share Posted July 4, 2006 Replaced mine with a cheapie from a large online shop. Probably prestolite, still going after about 3 years. Quote Link to comment Share on other sites More sharing options...
