Niamh Posted February 11, 2011 Share Posted February 11, 2011 Why are the bolts at the transfer box end of the front propshaft put in from the back so one can't remove them easily to replace with new bolts when changing propshafts? Niamh Quote Link to comment Share on other sites More sharing options...
stuck Posted February 11, 2011 Share Posted February 11, 2011 They are easy to remove, take the prop off then undo the big nut inside the flange. Quote Link to comment Share on other sites More sharing options...
jad Posted February 11, 2011 Share Posted February 11, 2011 Why are the bolts at the transfer box end of the front propshaft put in from the back so one can't remove them easily to replace with new bolts when changing propshafts? Niamh bloody good question!i would like to know the answer to this as well. They are easy to remove, take the prop off then undo the big nut inside the flange. i think you missed the point.... the diff end you dont have to undo the diff pinion nut. Could it be so its easier to support the propshaft while putting it on? Quote Link to comment Share on other sites More sharing options...
