Brett Posted July 4, 2006 Share Posted July 4, 2006 Did the first full service on the Disco last night, (since I've owned it) Full Landrover service history prior to me owning it. Attempting to drop the oil on the transfer box, removed the fill plug, oil looked a bit nasty. removed the drain pug, hmmmm..... Only part of the threaded section of the plug came out. Magnet is stuck up in the hole I didn't shear it off meself, it came out easy peasy, obviously done & hidden up by the shaved chimps at the dealer Do you reckon I'll be able to get the magnet bit out or should I start looking for a new box? Cheers Brett Quote Link to comment Share on other sites More sharing options...
white90 Posted July 4, 2006 Share Posted July 4, 2006 does it leak? if not drill/tap and put a new plug along side to drain the oil. Quote Link to comment Share on other sites More sharing options...
Brett Posted July 4, 2006 Author Share Posted July 4, 2006 does it leak?if not drill/tap and put a new plug along side to drain the oil. No, its not leaking. Good idea Tony, I hadn't thought of that B) Quote Link to comment Share on other sites More sharing options...
Daan Posted July 4, 2006 Share Posted July 4, 2006 just remove an m8 bolt from the bottom cover, the oil will come out I remember. Then continue to undo the other bolts to remove the cover, so you can have a look inside. Quote Link to comment Share on other sites More sharing options...
Brett Posted July 4, 2006 Author Share Posted July 4, 2006 just remove an m8 bolt from the bottom cover, the oil will come out I remember. Then continue to undo the other bolts to remove the cover, so you can have a look inside. Hi Daan, one of my mates also suggested that a minute ago, do you know if you need a gasket/RTV to reseal when you replace the cover? Quote Link to comment Share on other sites More sharing options...
white90 Posted July 4, 2006 Share Posted July 4, 2006 RTV suits the job fine use a large tray to catch the oil as it drips from everywhere Quote Link to comment Share on other sites More sharing options...
Brett Posted July 4, 2006 Author Share Posted July 4, 2006 RTV suits the job fineuse a large tray to catch the oil as it drips from everywhere Cheers chaps. Quote Link to comment Share on other sites More sharing options...
