DDO173 Posted February 21, 2011 Share Posted February 21, 2011 My Discovery has returned with a fault that cured itself a couple of weeks after I bought it. When the ignition is on I can operate the internal heater blower controls as normal on all settings up to 4. However if I leave the fan runnong (anything but 0) and turn the ignition off it contrinue to blow, but then can be turned off manually. As I said before it had this when I first got the car several months ago but the problem went away before I got chance to investigate further. There is every chance it may go again before I can solve it properly, but my guess is that its a relay somewhere. As the AC relay b (behind the kick panel near the accelerator) was knackered due to water running down the A pillar my thoughts are the problem may eminate from there - but has anyone any other ideas? Quote Link to comment Share on other sites More sharing options...
