Steve King Posted February 22, 2011 Share Posted February 22, 2011 My new to me TD5 has started making "wurra, wurra" noises on start up! It is exactly the same noise that you get with a 300TDI when the power steering fluid is low, except that the noise starts when the clutch is depressed and first gear is engaged. The noise continues when turning the steering wheel, but after 15 minutes or so I can't hear any unusual noises! I'm rather puzzled by the symptoms and although it sounds the same as the power steering pump, I'm wondering if it is the clutch? Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted February 23, 2011 Share Posted February 23, 2011 Dry spiggot bush in the flywheel....only makes a noise when you dis-engage the clutch and select a gear....box off is the only way to regrease or change the bush. Quote Link to comment Share on other sites More sharing options...
Phil Posted February 23, 2011 Share Posted February 23, 2011 I agree, it sounds like the spigot bush, I had this happen with my vehicle. I was told that changing it isn't urgent so I did it when I changed the clutch. Phil. Quote Link to comment Share on other sites More sharing options...
Steve King Posted February 23, 2011 Author Share Posted February 23, 2011 Thanks guys! Quote Link to comment Share on other sites More sharing options...
crwoody Posted February 23, 2011 Share Posted February 23, 2011 If its any comfort, I lived with this same fault on my Td5 90 for 3 years or more and it never got any worse. Sold the car on last year with it still doing it and I suspect it still is. Quote Link to comment Share on other sites More sharing options...
Steve King Posted February 23, 2011 Author Share Posted February 23, 2011 If its any comfort, I lived with this same fault on my Td5 90 for 3 years or more and it never got any worse. Sold the car on last year with it still doing it and I suspect it still is. It doesn't sound like really serious, but as I bought it from a dealer I think it should be sorted under warranty! Quote Link to comment Share on other sites More sharing options...
stuck Posted February 23, 2011 Share Posted February 23, 2011 Up to you if you want to pursue a warranty claim but my TD5 does that to. As you say after 10 mins or so it disappears, doesn't worry me. Quote Link to comment Share on other sites More sharing options...
ashtray Posted February 24, 2011 Share Posted February 24, 2011 mine too, for the first minute or so, gets louder as you select first, an annoying noise but its in the most inaccessible area, gonna change it when myy truck eventually needs a clutch Quote Link to comment Share on other sites More sharing options...
