subseauk Posted February 24, 2011 Share Posted February 24, 2011 Hi Got to renew some or all of wiring in wings to lights and indicators. Are the landrover colours used same as LUCAS standard? Have to ask as the bits hanging in the wings with no ends and the bits that were twist spliced and have parted due to corrosion are all different ( looks like what was at hand at the time used in several joints and extensions) I'd like to be able to go to an automotive sparky supplier tomorrow and pick up correct colours for heads, side and indicators. Also would like to know if these wing looms are wired directly into the relay or switch and what would be quickest way to change out existing wiring for new ie splice in again, replace wire terminations and if so what type required etc. Advice or Opinions. Appologies if this info is available somewhere on forums as i have done a search but not found anything decisive. Are headers plugs or joints or both? Any help appreciated as this is turning into a bit of a rush job. Rgds Kev Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted February 24, 2011 Share Posted February 24, 2011 Landrover's wiring colour coding is based on BS AU 7. Several places have details the web, here's one for a start and here is a better one which you can dowload and print out. Nick. Quote Link to comment Share on other sites More sharing options...
subseauk Posted February 24, 2011 Author Share Posted February 24, 2011 Landrover's wiring colour coding is based on BS AU 7. Several places have details the web, here's one for a start and here is a better one which you can dowload and print out. Nick. Many Thanks Nick There are some differences on the drawing i found namely the wire between the column switch & flasher / hazzard units is labelled LGN (light green & ?? ) on list shows light green and brown. but the main wiring colours will do for me as i only want to replace the earths and switch feeds. excellent help mate. rgds Kev Quote Link to comment Share on other sites More sharing options...
PaulMc Posted February 24, 2011 Share Posted February 24, 2011 Many Thanks Nick There are some differences on the drawing i found namely the wire between the column switch & flasher / hazzard units is labelled LGN (light green & ?? ) on list shows light green and brown. but the main wiring colours will do for me as i only want to replace the earths and switch feeds. excellent help mate. rgds Kev LGN is Light Green with a Brown trace. LG = Light Green N = Brown . Quote Link to comment Share on other sites More sharing options...
subseauk Posted February 24, 2011 Author Share Posted February 24, 2011 LGN is Light Green with a Brown trace. LG = Light Green N = Brown . Many thanks Paul Much appreciated, is there a list of the Land Rover specific abbreviations for these colourings do you know? What i have found so far: B - Black G - Green K - Pink L - Light N - Brown (ta) O - Orange P - Purple R - Red S - Slate ( grey i assume ?? ) U - Blue W - White Y - Yellow It seems that the last letter if more than one is used = trace colour Have i missed any?? Rgds Kev Quote Link to comment Share on other sites More sharing options...
western Posted February 24, 2011 Share Posted February 24, 2011 have you seen these in our tech archive index http://forums.lr4x4.com/index.php?showtopic=21345 http://forums.lr4x4.com/index.php?showtopic=13675 Quote Link to comment Share on other sites More sharing options...
western Posted February 24, 2011 Share Posted February 24, 2011 Many thanks Paul Much appreciated, is there a list of the Land Rover specific abbreviations for these colourings do you know? What i have found so far: B - Black G - Green K - Pink L - Light N - Brown (ta) O - Orange P - Purple R - Red S - Slate ( grey i assume ?? ) U - Blue W - White Y - Yellow It seems that the last letter if more than one is used = trace colour Have i missed any?? Rgds Kev your correct so far, also see the linked info above. Quote Link to comment Share on other sites More sharing options...
subseauk Posted February 25, 2011 Author Share Posted February 25, 2011 your correct so far, also see the linked info above. Once again Ralph, yet more wonderful links that would take us mere mortals a while to find Don't you ever sleep Rgds Kev Quote Link to comment Share on other sites More sharing options...
western Posted February 25, 2011 Share Posted February 25, 2011 Once again Ralph, yet more wonderful links that would take us mere mortals a while to find Don't you ever sleep Rgds Kev here to help, yep, more sleep & a lie in approching soon. Quote Link to comment Share on other sites More sharing options...
