ukspike Posted February 24, 2011 Share Posted February 24, 2011 So what's the best way please gents to fix the age old problem of the door card fixings coming of my 90 at the bottom corners, what type of fixes have you used. Quote Link to comment Share on other sites More sharing options...
Spearos Posted February 24, 2011 Share Posted February 24, 2011 Will be interested to hear some suggestions on this, as I am (very slowly) refurbing some doors. I plan to use the cards I already have on the 90 as they're fine apart from most of the fixing points being broken. One idea I did have (in the little amount of time spent thinking about this) is possibly using self tappers and the little caps normally used for the screws on number plates?.. These are what I mean: http://www.jhmbuttco.com/acatalog/info_WES0085.html Quote Link to comment Share on other sites More sharing options...
crwoody Posted February 24, 2011 Share Posted February 24, 2011 On the bottom corners, I ended up drilling a hole through the card from the centre of the original plastic fitting and then used a large stainless self tapper big enough to get a grip on the plastic "socket" bit that's left in the door. It's visible on the outer face of the door card but only in the corner, but then, so are the spot welds on the outsides of the rear panels, It's a Land Rover after all. Quote Link to comment Share on other sites More sharing options...
ukspike Posted February 24, 2011 Author Share Posted February 24, 2011 On the bottom corners, I ended up drilling a hole through the card from the centre of the original plastic fitting and then used a large stainless self tapper big enough to get a grip on the plastic "socket" bit that's left in the door. It's visible on the outer face of the door card but only in the corner, but then, so are the spot welds on the outsides of the rear panels, It's a Land Rover after all. Now that's a very good idea, only problem now is, where did I put that plastic corner plug, you need it I know, because without it you have a very large hole in the door metal work. spike Quote Link to comment Share on other sites More sharing options...
