ashtray Posted February 26, 2011 Share Posted February 26, 2011 good evening chaps! One of my friends is due to have his clutch changed on his 55 plate 110 td5 and he has been warned that it may need a dual mass flywheel replaced, which defenders have dual mass flywheels and can a standard flywheel be retrofitted? Cheers Ash Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted February 26, 2011 Share Posted February 26, 2011 IIRC all TD5's were fitted with the dual mass flywheels to help stop transmission noise....you can fit the solid flywheels with super heavy duty clutch's but sometimes you do get a bit of gearbox chatter if the box is a bit worn. Quote Link to comment Share on other sites More sharing options...
landy andy. Posted February 26, 2011 Share Posted February 26, 2011 All Td5's have DMF's. I would recomend an original Land Rover part, over anything else. But you can get a Rakeway clutch and flywheel (non DMF), BUT they use their own clutch, and this could cause a problem if the company goes under, or you have problems whilst away. Britpart also do a non DMF kit, but should be will be cack as is Britpart, Removing the DMF will cause vibration when pulling away, and this will not help your gearbox etc, and tends to cause a rattle whilst stationary. The original DMF is easily good for 100thou miles Andy Quote Link to comment Share on other sites More sharing options...
ashtray Posted February 26, 2011 Author Share Posted February 26, 2011 thanks k88 mud and andy, well his truck is a hell of a lot less vibey than mine so should be ok. I know 5-cylinder engines get a bit of a vibe on at mid to high revs but mine is lot more noticeable than his, do u reckon that is a dual mass fault? or possibly that the injectors need zeroing in? it does it in all gears but most pronounced in 3rd and 4th and i can get it on idle, shakes the gear lever to bits and i get a pronounced metallic rattle at about 3-4krpm ( guess as no rev counter) Cheers fellas! Ash Quote Link to comment Share on other sites More sharing options...
tacr2man Posted February 27, 2011 Share Posted February 27, 2011 Approx £525 + vat genuine , If you fancy going auto nows the time Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted February 27, 2011 Share Posted February 27, 2011 its only that price if you go to a stealer dealer roughly £300 ish anywhere else Quote Link to comment Share on other sites More sharing options...
pongo Posted February 28, 2011 Share Posted February 28, 2011 You have to ask yourself, if the DMF is so good, why, when they fitted the Puma donkey, did they ditch the Transit DMF and go for solid. Answer? They don't last. Mine went at about 85k miles. I have since fitted a Rakeway solid flywheel with conventional HD clutch. No vibes worth talking about, no judder, drives beautifully. My son has also fitted one to his 110. Quote Link to comment Share on other sites More sharing options...
