Honking noise from pressing brake pedal
Good Evening all
Today a new noise was discovered on my 110, earlier today the brakes felt a little soft when stopping outside my house so I checked fluid level - no cause for concern.
On leaving the house a little while ago I pressed the brake pedal before starting engine only to be greeted by a honking noise emanating from the rear of the car, good resistance on pedal though. This was repeated several times with no reduction in noise suffice it to say one of the neighbours came out thinking one of the gesse from the lake at the bottom of the road had wandered by for some food.
Currently I am thinking it may be the spring has let go on one of the shoes and the shoe is dragging on the inside of the drum.
Not able to start taking it all apart for the next few days, but I will appreciate any other avenues to explore.
Regards
 Share
