eds Posted February 28, 2011 Share Posted February 28, 2011 My hand brake has never played up before, it has been lubed when the gearbox came out and it has a new cable. It had been parked up for under a week. When I went to draw forwards there was total resistance and then a big snap and all was free. The hand brake was not applied! Any ideas as to what caused this, was it some kind of stick on the hand brake, or something more ominous? Thank you Quote Link to comment Share on other sites More sharing options...
oakesy Posted February 28, 2011 Share Posted February 28, 2011 surface rust and residue of condensation may have created a bind. So as you came to release it was still technically on but without the restriction. Was the noise from the rear or the next to you. As the rear could have locked with the weather conditions and lack of use. Similar as the handbrake near will cause binding if not used. Test to see if there irregular braking patterns when in use either tugging on left or right. Quote Link to comment Share on other sites More sharing options...
faseman7 Posted February 28, 2011 Share Posted February 28, 2011 if it was your handbrake then get a x-eng one, there mint. Quote Link to comment Share on other sites More sharing options...
eds Posted February 28, 2011 Author Share Posted February 28, 2011 Unfortunately not sure exactly where the noise came from. If it binds again I will be more ready to listen. As long as it could not be something majorly bad, i'll watch and see how I get on. Thanks Quote Link to comment Share on other sites More sharing options...
faseman7 Posted February 28, 2011 Share Posted February 28, 2011 Was probably the handbrake, those drums are a bugger when they get a bit of water in. Make sure the ujs on the prop are fine aswell. Quote Link to comment Share on other sites More sharing options...
