manxrover Posted March 1, 2011 Share Posted March 1, 2011 Hi All I had the problem of the fuel lines rubbing on the chassis 2001 TD5 and leaking, renewed the fuel lines all four, the problem is the pipe that leads to the engine passes through the chassis and conects to the pump via a square plug, since i had the work done the connector keeps blowing off, engine fails and dumps fuel on the road, three times now has any one had this problem and is there a cure, dont fancy changing the main fuel line. Regards Brian Quote Link to comment Share on other sites More sharing options...
