Disco 300tdi rear axle V's Def 300tdi axle
Sometimes yes, Most disco 300tdi's have a 3 bolt propshaft, so the flange on the diff is different but it can be changed, other than that they are the virtually the same halfshafts are one piece on the disco cant remember if they are on defender.
HTH
Dave.
HTH
Dave.
Dave
Not fussed with the diff as i'll be using my original.As long as the internal's are the same for both axles then thats ok.It's easier to get hold of a Disco axle. I'm converting my Salisbury to Disc's.
Cheers
Ralph
Stub axles are different on the Salisbury axle. Rear discs are different too, Disco rear discs are smaller than 110 rear disks (which are the same as 90/110 fronts). Calipers are different too (110 ones are different shape to accommodate larger disc).
i'll be using the 300 hubs/stub axles/shafts.
Disc's/calipers will be 110
