phil37 Posted March 2, 2011 Share Posted March 2, 2011 Hi i am looking for a wiring diagram for a discovery td5 03 reg. Land rover have now had this vehicle for 5 weeks for a starting fault vehicle runs for 3 seconds then cuts out all it will do after this is turn over. I am looking for the diagram for the immolizer and starting if any one could help. Phil. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted March 2, 2011 Share Posted March 2, 2011 Fish out your credit card and log on to www.landrovertechinfo.com and for a small fee you can download everything you can ever need. I don't think the 03MY are covered by RAVE at all. If it starts, runs and then cuts out it is probably a screwed up immobiliser code as IIRC that is exactly what they do - it will fire, run briefly then stop because the engine ECU doesn't see a valid code within a certain time. That being the case you need to plug in Testbook, tell the Td5 engine ECU "learn" the immobiliser code and it should work. Five minute job. If it isn't that it is probably a related fault - such as maybe the immobilisation code is not being provided to the ECU for some other reason. Quote Link to comment Share on other sites More sharing options...
phil37 Posted March 3, 2011 Author Share Posted March 3, 2011 Hi i am sure that landrover would have tried that i think you could be right about it being a immobiliser fault they are arranging for it to go to a sparkey to be looked at. Thanks for your reply phil Quote Link to comment Share on other sites More sharing options...
