Welder
Pics on arrival, reasonable duty cycle
should help keep the workshop warm :)
S-MIG 410-1 + S-MIG 4x4 4 roll feeder + 5M intercon - medium to heavy duty fabrication.
RRP £1490+VAT
Supply Voltage 230V
Welding Range (amps) 40-410
Duty cycle -60% @ 350 amps :blink:
Duty cycle -45% @ 400 amps - Should make the house lights flicker :lol:
Voltage Steps 24
Fuse rating slow blow 32/45A
Weight approx 115kg
Wire Feed S-MIG 4x4
Mig wire range 0.6-1.6mm
Inductance Settings 2
Torch trigger latching Standard
Work lead (earth) 3M
Mains input lead 3M rubber
Intercon lead length 5M Standard
Standard features; Very rugged & compact wire feed unit, synergic control means very easy to set & use,
Oxford Cap+ technology ensures a very smooth stable arc with the best arc starting, electronic motor
brake & burn back fitted, torch trigger latching fitted, very energy efficient design.
Options;Digital meter kit, Spool cover, Upgrade to 10M, 15M or 20M intercon
Every Oxford welding machine is offered with the following guarantees:
2 year warranty all items
5 year main transformer warranty (the heart of the machine)
20 year minimum guarantee of spares availability
Gone for the 10 mtr inconector, digi display and wire spool cover plus MB25 and 36 both
4 metre and 8 metre earth
http://www.oxfordwelders.co.uk/singlephasemig.html
:ph34r:
May the force be with me
:rofl:
Nige
Nah
Fed up with welding up shims :D
Used one at my mates workshop, he reckoned it out performed the 3 phase ESAB they had, and thats
saying something, I had a go, and was sort of :blink: in love :wub: in a manly fabricatory sort of way
you understand :)
I'm a huge beliver in having some thing good running at 40% all day long than something OK and
flat out all the time, synergic is also a extra bonus
Nige
Yup :)
the base can sit in the workshop, the top unit with the wire a welding gun can be moved 10 metres from
base unit which brings portability from dragging 120 kgs of welder about, plus a 4 metre torch and
8 metre earth makes for easier access
Synergic - full Synergic means that it will automatically adjust the voltage according to whatever wire feed speed you tell it
you are using - ie you set in say 1.00mm and the typeof metal - say steel, and thickness, this then sets
the machine to a start point, start welding and the machine will make cointinous minor adjustments - ie
you will see current and wire speed move, maybe a fair bit on starting, less as it "tunes" the perogfram. often
the programs can then be saved for future use on same jobs etc
this one can be switched off, but synergic is new to the single phase units, has been the preserve
of big £s 3 phase till last year or so
the one I am getting is not full synergic - from oxfords site :
"These machines feature synergic control. This means the wire speed increases as the
welding voltage increases, so once the wire speed control is set, changing the output
voltage setting will change the wire speed automatically and no further adjustment of wire
speed is normally necessary."
Nige
The Oxford welders are made by the same people (Technical Arc Services), that make the Portamig welders that have been discussed on here before.
FWIW, I have a Portamig 215, that's been great over the last 4 years or so. The Oxfords look similar, and have pretty decent specs.
Luke
Very nice Nige.
Thats a bloody big plant to run on single phase,
At least it gives you the option of turning the synergic off, i've never got on with synergics the damned things always seem to mess around with the settings right when your in the midle of the most critical or visible weld.
I think the synergic function is more suited to production rather than the infinate vairiables we face on most jobs.
If your house electrics system uses MCB’s then you will need a 63A class C MCB........... I run a single phase 300A synergic.
I have also fed the workshop with a single feed from the distribution box of 10mm twin & earth.
Also my nearest neighbour (100 yards away) complains about the lights flickering when I am welding. I pointed them in the direction of the electricity company for a solution and heard no more about it.
which I sneaked in and connected to my nearest neighbour (100 yards away) complains about the lights flickering
:P
:rofl:
Nige
PS - Ta for the Info BBC :)
Mostly because they're pretty expensive.
I'd love an AC tig set, but I'm going to be a while saving up for it!
Looks good Nige,
Show us some weld porn!
As above I have a very nice Portamig that has done me proud for a few years and today I picked up a 160 Amp AC / DC Industrial TIG, just got to work out what all the settings do
TIG welding Aluminium, how hard can it be?!
