wib Posted March 4, 2011 Share Posted March 4, 2011 just put my defender front end back together as i have had it resprayed, the front lights wont work, the side lights work. there is live to the switch and live out of the switch on side light and on dip but still no lights are there eney relays in the dash and the fuses are all new i have checked the fuses with a test light as and when you switch the lights on and allis good thanks wib Quote Link to comment Share on other sites More sharing options...
TS888 Posted March 4, 2011 Share Posted March 4, 2011 What model year? One common source of this problem is the dim/dip relay has packed it in, if you have a truck built in the years with dim/dip/ Quote Link to comment Share on other sites More sharing options...
wib Posted March 4, 2011 Author Share Posted March 4, 2011 land rover defender 1988 200 tdi where is the dim dip relay Quote Link to comment Share on other sites More sharing options...
western Posted March 4, 2011 Share Posted March 4, 2011 dim dip unit is the black box behind the instrument pack, 2 screws secure it & to get access to them for removal means removing the dash top padded rail, or leave it in place & disconnect the plug from it & secure the plug safely, so it canot get caught up anywhere. by disconnecting the plug, normal side/dip beam will work as normal, the vehicle will not fail the MOT, as dim dip requirements was removed from UK vehicle lighting regs. Quote Link to comment Share on other sites More sharing options...
wib Posted March 4, 2011 Author Share Posted March 4, 2011 thanks for that western il strip it tomoz and have a look Quote Link to comment Share on other sites More sharing options...
