subseauk Posted March 5, 2011 Share Posted March 5, 2011 Hi guys Yet another discovery whilst the rad is out and painting being done. I noticed a bolt apparently missing from the nearside of the front (see photo 2), Photo 1 shows the bolt in place on the offside point. Is this actually missing or is it like an optional bolt point for a towing bracket? I have tried looking at several parts manuals (inc russian!! ) but this would be best guess Any info appreciated. Rgds Kev Quote Link to comment Share on other sites More sharing options...
western Posted March 5, 2011 Share Posted March 5, 2011 should be a matching bolt as it attaches the lower part of the wing panel to the chassis, definitly 2 on my 110. can't find a number for that bolt though in microcat or paper parts book. Quote Link to comment Share on other sites More sharing options...
subseauk Posted March 5, 2011 Author Share Posted March 5, 2011 should be a matching bolt as it attaches the lower part of the wing panel to the chassis, definitly 2 on my 110. can't find a number for that bolt though in microcat or paper parts book. Cor Blimey Ralph.......we're struggling tonight mate!!! I will have to do some forum jumping on this one, i did see a bolt shown on the russian parts site but other than showing one there not a lot of use unless you par'lez ruski rgds Kev Quote Link to comment Share on other sites More sharing options...
subseauk Posted March 5, 2011 Author Share Posted March 5, 2011 should be a matching bolt as it attaches the lower part of the wing panel to the chassis, definitly 2 on my 110. can't find a number for that bolt though in microcat or paper parts book. Hey Ralph Would i be right in thinking it may be the bolt ( item 10 ) shown in this layout?? rgds Kev Quote Link to comment Share on other sites More sharing options...
western Posted March 5, 2011 Share Posted March 5, 2011 that bolt is not mounted high enough on the chassis, but it might be the right length/item, it attaches the inner bottom part of the front wing [not the galvanised wheel arch] Quote Link to comment Share on other sites More sharing options...
subseauk Posted March 5, 2011 Author Share Posted March 5, 2011 that bolt is not mounted high enough on the chassis, but it might be the right length/item, it attaches the inner bottom part of the front wing [not the galvanised wheel arch] bugger, thought i might be on a winner there!! oh well, back to the hunt cheers Ralph Kev Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted March 5, 2011 Share Posted March 5, 2011 I thought that big bolt (through the tube mounted on top of the chassis rail) was for the steering box reinforcing arm? Hence why there's not on on the nearside...as your vehicle is RHD? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted March 5, 2011 Share Posted March 5, 2011 Yes, it is. See mine below: Off-side (with reinforcing arm visible and bolts fitted): Near-side (no arm visible, bottom bolt only for steering guard mounting): Quote Link to comment Share on other sites More sharing options...
subseauk Posted March 5, 2011 Author Share Posted March 5, 2011 Yes, it is. See mine below: Off-side (with reinforcing arm visible and bolts fitted): Near-side (no arm visible, bottom bolt only for steering guard mounting): Hi Retro To be honest i only noticed after tidying up and putting stuff away so never got under wheel arch today but will definately go under again tomorrow. Does your frame still have the tubular fitted on both sides between the inner wings even if only one in use? ie is this so the chassis can be used for RHD an LHD ?? Mine is RHD and i'll post update tommorow, would be nice to find something has'nt been left out or dropped off for a change!!! Cheers Kev Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted March 5, 2011 Share Posted March 5, 2011 Yep, the tubes are fitted to both sides on my 90 as in the photos above. I just popped out to take them so they're current! The mounting holes for the steering box itself are on the LHS as well you will notice The reason is as you say, so that the chassis is usable for LHD or RHD vehicles. Quote Link to comment Share on other sites More sharing options...
western Posted March 6, 2011 Share Posted March 6, 2011 good spot James, that would be right then, the bolt I was looking for must be further forward, as on the RH side it was a real pain to get at when I had to remove the wing. I'll check my 110 in the morning. Quote Link to comment Share on other sites More sharing options...
western Posted March 6, 2011 Share Posted March 6, 2011 just looked at my 110 & it's as per the photo's above. the bolt I thought it was is directly above. Quote Link to comment Share on other sites More sharing options...
subseauk Posted March 7, 2011 Author Share Posted March 7, 2011 just looked at my 110 & it's as per the photo's above. the bolt I thought it was is directly above. I'm just relieved its not another problem Rgds Kev Quote Link to comment Share on other sites More sharing options...
western Posted March 7, 2011 Share Posted March 7, 2011 apologies for the initial confusion. Quote Link to comment Share on other sites More sharing options...
subseauk Posted March 7, 2011 Author Share Posted March 7, 2011 apologies for the initial confusion. Quote Link to comment Share on other sites More sharing options...
