del Posted March 7, 2011 Share Posted March 7, 2011 Ive got a bolt on my alternator (200tdi) that has sheared off , its the bolt at the bottom that seems to go through the steering pump . It has started making a clanging noise were its vibrating , how does it fix ? , whats the best way to tackle it? , any ideas would be appreciated, del Quote Link to comment Share on other sites More sharing options...
western Posted March 7, 2011 Share Posted March 7, 2011 bottom front or bottom rear bolt ? these just attach the alternator to the combined PAS Pump/Alternator bracket, see page 200 there should be 2 x bolt item 19 1 from front & 1 from rear [not shown in diagram] bolt item 13 goes through the engine block & screws into bracket item 2, just where the line from the number 2 touches the bracket, this also secures the engine to chassis earth cable [not shown] easiest way to extract the broken bolt is to remove bracket item 2 from the engine & drill it out on the workbench. Quote Link to comment Share on other sites More sharing options...
del Posted March 7, 2011 Author Share Posted March 7, 2011 spot on thanks Quote Link to comment Share on other sites More sharing options...
