musbmad Posted March 8, 2011 Share Posted March 8, 2011 Hi Does anyone have the fitting instructions and template for A Safari Snorkel to fit a Discovery 300Tdi non ABS I would return as soon as snorkel fitted Many Thanks Jim Quote Link to comment Share on other sites More sharing options...
sargejnr Posted March 9, 2011 Share Posted March 9, 2011 Is it the safari one that comes out half way down the wing or the Southdown one that comes out closer to the windscreen? Quote Link to comment Share on other sites More sharing options...
barmiebrumie Posted March 9, 2011 Share Posted March 9, 2011 Just fitted one to mine (300tdi) but with ABS will check but I think the instructions were for both so might be good for you, will try to look tonight John Quote Link to comment Share on other sites More sharing options...
musbmad Posted March 9, 2011 Author Share Posted March 9, 2011 Its the one that comes halfway down the wing, Cheers John that would be great Thx Quote Link to comment Share on other sites More sharing options...
sutty_32 Posted March 10, 2011 Share Posted March 10, 2011 If you get a large bit of cardboard and hold it against the snorkel you should be able to make your own template As far as instructions, remove wheel arch plastic inner, drill one large hole (using hole saw if possible) where it passes through inner and outer wing, and holes for it to bolt onto in the outer wing. Then grind the ribs off the air box on the side closest to engine (need to remove air box) and then cut a hole in it. Silicon and attach the snorkel bit, and remove standard air intake pipe from the front of the air box blanking the hold with the plug provided. Its a fairly straight forward job, providing you have all the parts its quite hard to go wrong, just measure twice and cut once Quote Link to comment Share on other sites More sharing options...
barmiebrumie Posted March 10, 2011 Share Posted March 10, 2011 Its the one that comes halfway down the wing, Cheers John that would be great Thx PM me your address & i'll get it posted out John 07930 367 659 Quote Link to comment Share on other sites More sharing options...
musbmad Posted March 10, 2011 Author Share Posted March 10, 2011 Thanks all for your help and advice Cheers Jim Quote Link to comment Share on other sites More sharing options...
