Puffernutter Posted March 9, 2011 Share Posted March 9, 2011 They say "if it ain't broke don't fix it"! All I was doing was checking the friction material thickness on the shoes at the rear and the depth of material on the pads at the front. So, first I could get the drum screw out, so they had to be drilled off, I backed off the adjusters and got the drum off - depth of friction material was fine. On the second one (offside) there was evidence of a leak on the wheel cylinder, so I ordered a new one and replaced it today. Of course, neither of the brake fittings would turn around the brake pipe, so they both sheared and I had to make up a new brake pipe (flaring brake pipes is not my favourite job!) So all back together, bled through, adjusted up and the pedal still goes to the floor. Re bled, re-adjusted and the pedal still goes to the floor. A few pumps and its hard, but it doesn't last long (I know that problem!) can you get viagra for Land Rovers? So, any thoughts, where do I start - it was all working fine at the start of this week! I was hoping to make it better, not worse! Cheers Peter Quote Link to comment Share on other sites More sharing options...
Frax Posted March 10, 2011 Share Posted March 10, 2011 I would just keep bleeding it as there must be air in the system somewhere or you have a leak. Frax Quote Link to comment Share on other sites More sharing options...
Puffernutter Posted March 25, 2011 Author Share Posted March 25, 2011 Broken adjuster! Replaced, all adjusters re-adjusted and back to normal! Cheers Peter Quote Link to comment Share on other sites More sharing options...
