need4speed Posted March 14, 2011 Share Posted March 14, 2011 Just wondering if anyone can tell me the differences between the LT230 and LT230Q? I know the LT230Q is supposed to be quieter but is that really the case? Is it a noticeable difference? What parts are different in order to make it quieter? Quote Link to comment Share on other sites More sharing options...
TS888 Posted March 15, 2011 Share Posted March 15, 2011 They changed the cutting on the gears, which makes the 'Q' run quieter. I've been told by others the difference is noticeable in a Defender, less so in a Disco as there is more sound deadening. No personal experience. Quote Link to comment Share on other sites More sharing options...
Andrew Chua Posted March 17, 2011 Share Posted March 17, 2011 No difference on mine. From Q to non q version. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 17, 2011 Share Posted March 17, 2011 This is the supposed differences: INTRODUCTIONThe LT230Q transfer box is mounted at the rear of the main gearbox and transmits drive to the front and rear axles via the propeller shafts. The LT230Q, while similar to the LT230T differs mainly in the following areas: • Helix angle of gears increased to 31° together with an increase in the number of gear teeth thus giving quieter running and an increase in power transmission efficiency. • Increased length mainshaft input gears together with increased thickness bearing housing and repositioned bearing. • Redesigned intermediate gear bearings. Redesigned high gear bush giving quieter running Taken from here: http://www.muddyoval.com/articles/generalinfo/LT230.htm Quote Link to comment Share on other sites More sharing options...
Andrew Chua Posted March 18, 2011 Share Posted March 18, 2011 Yup thats what I read too. I was expecting more noise, but maybe my truck is 9yr so the gearbox is grouchy. But the tbox is 19yrs. So my experience, it sounds the same. Quote Link to comment Share on other sites More sharing options...
