greenstream Posted March 18, 2011 Share Posted March 18, 2011 Hi Im in the process of building a Light Weight body on a RR-chassis. The chassis is of course running axles with discbrakes. therefore I need a brakeservo and its got to fit in the Light Weight enginebay, which seems a little small. Can I use the servo from the Light Weight or do I have to change and if so are there other servo's around which are small in diameter. I know about the early RR-classics but I wouldnt mind if it was a newer LR/RR part. Cheers Morten Quote Link to comment Share on other sites More sharing options...
western Posted March 18, 2011 Share Posted March 18, 2011 pre 300tdi brake servo in a 90 or 110 is a smaller diameter, but quite thick front to rear. Quote Link to comment Share on other sites More sharing options...
