I have a 2002 td5 defender 90. When you reach between 65/70 mph it feels as though the engine has limiter the turbo seems to stop working.If you stop and start again the engine is fine and the turbo is working. Any ideas it has just had a new genuine rr airflow metre fitted .
Link to post
Sounds to me like the turbo boost had been adjusted too far, the pressure is monitored by the ECU and if it goes over the limit (1 bar?) the ECU goes into "limp" mode until it's shut down and re-started.
Link to post
Also check red plug on ECU for oil, had one doing the same it was oil in the loom. The wastgate in the manifold can seize up. Under the heat shield there's a rod and on one end there's the wastgate actuator, the other end is the wastgate (just a lever going into the manifold) you need to make sure this is free to move it will be hard to move but it should.
Link to post
