jericho Posted March 29, 2011 Share Posted March 29, 2011 My experience is No. Tried it to power my milemarker on a 300 tdi with a 30cc pump - 6" pulley on the pump,well over 180 degrees contact and the spring tensioner locked in place to prevent slack under load. It worked wonderfully when tested in the yard - first time I was up to the bonnet in slop and really needed a winch,it was useless. I was going to try a synchronous belt,but had a chat with Rakeway engineering,and they warned me against toothed belts - they are non-stretchy,and will snap with the smallest stone underneath them,so must be fully enclosed in a guard. Poly-vees can transmit big power no problem,but not in mud and slime. Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted April 2, 2011 Share Posted April 2, 2011 I agree with Simon, it's a matter of what power the winch pump will ned but up to 30 Hp (including the alternator draw) should be available on the serpentine belt. The will work when wet, not sure about in thick mud though< I don't think many manufacturers test for that. Quote Link to comment Share on other sites More sharing options...
robhybrid Posted April 2, 2011 Share Posted April 2, 2011 Is the pump drive on mitsimog a toothed belt? Quote Link to comment Share on other sites More sharing options...
Escape Posted June 16, 2011 Share Posted June 16, 2011 After some testing in Russia's rivers and swamps, I am pleased to say the serpentine belt didn't have any trouble driving the 8.5cc pump on a 1:1 ratio. Even when soaking wet there was still enough pull, even on the outer layer, to get us up the muddy bank without drive assist. So very happy with it, perfect for my use, but for a bigger pump (and faster winch) other solutions would probably work better. Filip Quote Link to comment Share on other sites More sharing options...
simonr Posted June 16, 2011 Share Posted June 16, 2011 I was right then! It's nice to know your experience matches mine. Actual experience beats 'expert opinion' every time in my book! Si Quote Link to comment Share on other sites More sharing options...
